Troubleshooting Your MegaSquirt® V3 Main Board
sec 10 a.Do you have RPMC installed? Some people have had trouble finding a supplier for one, and assumed the stim would work without it.
What is a RPMC?
SEC. 7) Check to see what (if any) functions work. Try the loopback test, the serial communications test, the clock count-up of the processor, and check for power and ground to the pins of the processor (see the assembly guide steps for details).
**** Verify that no components are touching the crystal (Y1), which might prevent it from working properly.*****
**** The assembly manual said NOT to install the Y1 crystal, that it is not used for V3. The statement above makes me assume that it is used & required.****
Which is right? used or not used?
testing
Re: testing
This looks like you are using the B&G MS1 directions for an MS2 built for MS2/Extra code; you should use the directions at MSExtra.com.
The RPM C pot is a course adjustment knob for RPM. It is present on the JimStim and very early versions of the regular Stim. The V2.0 and later regular Stims do not have it.
Re: testing
Please tell me exactly what manuals to use.
I'm building a MS2 V3. firmware 2.92
Batch injection, supercharger, Jacobs(same as MSD), wide band O2, V8 ford 390 cid.
My life goal is to make this work. I can do it.
right?
My using a computer is just not that good so I know this is my fault. Although I do have a good knowledge of using tech manuals(specifically mechanical) I just need to know which ones I should be using. back to the beginning.
right?
Re: testing
Do you have a particular reason to use that firmware?jrods2 wrote:Please tell me exactly what manuals to use.
You'll likely get a better result and more support using the more common MS2/Extra firmware. See the Downloads and Manuals links above.
Re: testing
Do you have a particular reason to use that firmware?jsmcortina wrote:Do you have a particular reason to use that firmware?jrods2 wrote:Please tell me exactly what manuals to use.
No particular reason. I started this a year ago and their has been changes made and upgrades added and I believe that's where my problem started. Just as long as the MS2 I have will be compatible with the MS2/Extra firmware I see no problem there.
Thank you Jim
