Once it is reflashed, can you elaborate on how exactly it is not responding properly? I do not understand what you mean by "no Controll on tunerstudio."thewestie wrote: Flashed aging with 3.3.3 and still shows 2 controllers lights on ecu don't respond properly. Plugged in budys Jimstim fidle and pump log up but no Controll on tunerstudio. Had enough for one night.
lights on megastim
Re: lights on megastim
First, get it flashed with 3.3.3; the screen shots you posted are for B&G code.
With 3.3.3 my megastim will connect to tunerstudio and see changes. When I use a friends jimstim it won't connect.
Thanks again everyone with your help I'm gonna be a pro at this the very least I'll get my post count up and look like a pro
87 Turbocoupe 351w swap with a TKO, someday a turbo car again.
MS2 3.0 3.4.0
MS2 3.0 3.4.0
Then something is wrong with your friend's JimStim.thewestie wrote:With 3.3.3 my megastim will connect to tunerstudio and see changes. When I use a friends jimstim it won't connect.
What about the lights on the ecu
MS2 3.0 3.4.0
MS2 3.0 3.4.0
Are you saying that it will not trigger the injector lights on the Stim in output test mode, even though it is communicating? Or is there a different problem?
Woll not triger lights on stim on test mode. Lights on ecu do difrent things on 3.3.3. As to 2.9. I sent you and email with a video. I cant attach vid to ms extra
MS2 3.0 3.4.0
MS2 3.0 3.4.0
in this test mode I cant get the lights on the mega stim to light up
What are d14 d15 d16 do they light up but make no sence
MS2 3.0 3.4.0
MS2 3.0 3.4.0
The function of D14, D15, and D16 will depend on your tune file.
If you click Enable Test mode and then Fuel Pump On, does the fuel pump LED light on the Stim?
Yes and fidle on and of.
Thanks.
Thanks.
MS2 3.0 3.4.0
MS2 3.0 3.4.0
Try setting 1000 injections and an output interval of 30 ms.
no lights
MS2 3.0 3.4.0
MS2 3.0 3.4.0
What if you set it to test both?
Tried it and every combo ill try again
MS2 3.0 3.4.0
MS2 3.0 3.4.0
And removing the CPU and grounding the pins on the socket WILL turn on the injector lights - is that correct?
Yes.
MS2 3.0 3.4.0
MS2 3.0 3.4.0
This sounds like it may be a CPU issue. You can contact your kit seller directly by email to see if the daughter card is still under warranty.
I got it through diy
MS2 3.0 3.4.0
MS2 3.0 3.4.0
I've sent an RMA form.
We've traced it to a daughter card fault and replaced the card under warranty. New one shipping out today.
Great. I'm excited to get it going. I'll keep thread updated.
MS2 3.0 3.4.0
MS2 3.0 3.4.0
