lights on megastim
Re: lights on megastim
First, let's get the injector outputs sorted. See this article for how to check them.
http://www.diyautotune.com/tech_article ... ooting.htm
jumped 21 and 22 and it still passes the test. ill still do the rest of the testing as if it failed
87 Turbocoupe 351w swap with a TKO, someday a turbo car again.
MS2 3.0 3.4.0
MS2 3.0 3.4.0
Everything checks out till i get to. If the signal is making it to Q1 or Q5, but the injector driver isn't working, first check for continuity from pin 2 of the FET to the DB37.
i dont know what a fet is i googed it and looked at parts list?
MS2 3.0 3.4.0
MS2 3.0 3.4.0
Im also confused as to witch pon on q1 to test
MS2 3.0 3.4.0
MS2 3.0 3.4.0
Tested pin 21 & 22 with led and get constant illumination no blinkblink?
MS2 3.0 3.4.0
MS2 3.0 3.4.0
So i have looked and looked. Found lots of threads that just stop with no conclusion. I dont want that for this thread. What what does one do when they mess up a build.
Help.
Thanks Steven
Help.
Thanks Steven
MS2 3.0 3.4.0
MS2 3.0 3.4.0
Ok, it sounds like the circuit itself is working. What if you try injector test mode on the Stim?thewestie wrote:Tested pin 21 & 22 with led and get constant illumination no blinkblink?
Is that through tunerstudio. I have bothe mega stim and borrowed a jim stim. Not familiar with the jim stim.
MS2 3.0 3.4.0
MS2 3.0 3.4.0
When i hit start inj counts down 4 3 2 1 but jo light in stim or ms
MS2 3.0 3.4.0
MS2 3.0 3.4.0
Try reloading the firmware and starting with the default tune.
When i detect it shows 2 ms3.3.3.can i have loaded the firmware twice?
MS2 3.0 3.4.0
MS2 3.0 3.4.0
Maybe. It won't be a problem if you did.thewestie wrote:When i detect it shows 2 ms3.3.3.can i have loaded the firmware twice?
So I show my lack of computer skills again. Took me well over an hour to to flash the firmware. Tried 2.92 it still showed 2 controllers when detecting. No ing lights on stim but it looked good on the three lights on the ecu. Using BG 2.92 example. I played around and started to configure a tune and set ecu to 1 for ms2. Every time I pulled power and repowered up the stim it would say controller configuration error and tunerstudio was 1 but controller was 2. No matter how many times I hit burn it wouldn't take. Flashed aging with 3.3.3 and still shows 2 controllers lights on ecu don't respond properly. Plugged in budys Jimstim fidle and pump log up but no Controll on tunerstudio. Had enough for one night.
MS2 3.0 3.4.0
MS2 3.0 3.4.0
Played with it again. Starting to get realy bummed out.
MS2 3.0 3.4.0
MS2 3.0 3.4.0
When detecting you should be coming up with 2 ECUs. The difference between them is the driver that it is using to communicate with the ECU. JSSC is the new driver and RXTX is the old one.
What are you changing to 1 that keeps going back to 2 and results in a configuration error?
If you load the wrong firmware (MS2 comes in 3 different hardware configurations each with their own firmware) the outputs won't work correctly, a MSQ or a screen shot of Tunerstudio while connected can help to make sure that isn't the issue.
MS3+X on 73 Karmann Ghia ignition only with LS2 truck coils firing in sequential, fuel next.
2333(103*70) Type 4 with DTM also sitting in living room just need exhaust.
first atempt at screen shot
MS2 3.0 3.4.0
MS2 3.0 3.4.0
bigger than i thought
MS2 3.0 3.4.0
MS2 3.0 3.4.0
this is current
i'm trying thanks all for your patience
MS2 3.0 3.4.0
MS2 3.0 3.4.0
witch firm ware do i use ?
MS2 3.0 3.4.0
MS2 3.0 3.4.0
try again
MS2 3.0 3.4.0
MS2 3.0 3.4.0
