Sorry, total newb here, and hopefully this is the correct forum for this question.
I loaded the latest firmware for my S14 DIYPNP ECU. I also found the base maps for my exact configuration on the MS site I downloaded that I would like to use to start out with. However, the firmware I have does not support the base maps, and I need to find either 3.2.1, or 3.3.1 firmware to flash in order to use them.
I have been searching and cannot find either. Are they still around somewhere?
Would I be better off using the firmware I have now, and simply replicating the fuel/timing tables?
Thanks in advance.
MS DIYPNP archive firmware
Re: MS DIYPNP archive firmware
When you says "does not support" what do you mean?
You can load older tunes into newer firmware version - TunerStudio will automatically convert the tune and warn you of any mismatches.
Thank you.
I will try again, and send a screen capture if I get a error. Its probably just user issue (me). LOL
