LC-1 Analogue outputs
Hi folks,
I seem to be getting no output from either analogue out of the LC-1. If I connect Logworks up I can read back to AFR no problem, however there seems to be no signal/voltage on either of the 2 analogue outputs. Both are set to 0v=7.35AFR and 5v=22.1
The sensor and the controller work as I can see this using Logworks, but nothing through MS and nothing measured on a meter.
I have only ever used o/p 1 so thought there maybe a problem with this and switched to output 2 - still no joy.
Would both outputs fail at the same time?
Re: LC-1 Analogue outputs
Possibly. I'd contact Innovate directly to see what they have to say.
darrens wrote:Hi folks,
I have a BIG box full of LC-1 controllers with dead analog outputs.
Support the developers!
If the only thing that's dead are the analog outputs, that would be perfect for getting a per-cylinder AFR setup (or setups depending on how big the box is) when used with an MS3 and a TinyIOx.prof315 wrote:I have a BIG box full of LC-1 controllers with dead analog outputs.
Contacted Innovative - total blank.
Would anyone recommend the LC-2 or would folk recommend getting something different?
The LC-1 was bad, I went through 3 of them, two replaced under warranty but I ended up throwing them all away. So it was with great reluctance that I bought an LC-2 not long ago, I haven't got a lot of miles on it but it seems to be OK. I have more miles on the Spartan 2 from www.14point7.com, I would recommend that, plus he's got a nice feature built in for calibration.
Graduate of EFI University.
Thanks for the info, will take a look at the 14point7 stuff
If you are handy with a soldering iron the SLC OEM Eval kit is pretty nice too! Bulkier but a few bucks cheaper.darrens wrote:Thanks for the info, will take a look at the 14point7 stuff
Mmm.. interesting, appeals to me as everything on the car in terms of wiring is custom. I hate wiring that isn't the correct length, untidy etc.
The LC-2 seems to come with massively long cables. And cutting/shortening these would void a warranty.
More reading...
More reading...
