Hi all,
I'm running an MS3 with MS3x and relay board. It's going on a 440 in a Dodge Challenger. I've assembled the harness on my bench and am validating connections and functionality before installing into the car. At this point I've validated CLT, MAT, TPS, MAP (onboard and in manifold), VR Crank, Idle Stepper are communicating with Tuner Studio.
I'm intending on full sequential with a 36-1 trigger and cam position sensor (3-wire from a jeep). I'm able to spin the trigger wheel by the VR sensor and see the tach register the revolutions as well as on the tooth logger. I've connected the Cam sensor to the cam input on the ms3x along with 5v and sensor ground on the relay board. I must have something not right as I don't see anything on the composite logger when I spin the sensor. Settings, or wiring, or a combination. Any thoughts of how to troubleshoot this?
sensor and input bench testing
Re: sensor and input bench testing
Use 12V instead of 5V that will have a stronger signal.peterro wrote:Hi all,
I'm intending on full sequential with a 36-1 trigg.I've connected the Cam sensor ter and cam position sensor (3-wire from a jeep). I'm able to spin the trigger wheel by the VR sensor and see the tach register the revolutions as well as on the tooth loggero the cam g witinput on the ms3x along 5v and sensor ground on the relay board. I must have something not right as I don't see anything on the composite logger when I spin the sensor. Settings, or wiring, or a combination. Any thoughts of how to troubleshoot this?
Check the voltage on the cam sensor - what's it doing as the sensor revolves?
This is the sensor pigtail I'm using so I hooked the orange to 5v ref, and black to the TPS return. Apply power and check voltage on the yellow signal wire using a return as ground and there is no voltage change when turning the sensor. Do you see any issues with that process? I think I need a new sensor.
What voltages should I expect for on/off?
It should go from 0 to 5 volts and back again.
You may need a pull-up resistor (1K from VREF to signal) for this sensor to work properly.
The resistor worked great! Thanks.
