channel name for datalog in
What is the internal channel name for the datalog in (pin 30 on the MS3X) ?
Re: channel name for datalog in
When I open up the firmware for, say, adding table switching and bring up the input pin drop down menu I see it as....... datalog in. Is that what you mean or are you referring to something else?
Graduate of EFI University.
Perhaps you mean the raw pin name/bit. See the Datalog fields section of the TunerStudio reference manual.
Thank you
Well, I've tried setting up a gauge with PTT6 input and a maf frequency on the datalog wire, but it doesn't seem to yield any results. Back to square 1.
As I said before, if you want dual frequency MAF support you'll need to write custom firmware to support it and that's not an easy task.
Do you mean that's necessary just to see it's frequency output as well ?jsmcortina wrote:As I said before, if you want dual frequency MAF support you'll need to write custom firmware to support it and that's not an easy task.
Using an on/off indicator is absolutely not going to work. Did you try my suggestion of configuring a speed sensor input?
Yes, but it didn't work either.jsmcortina wrote:Using an on/off indicator is absolutely not going to work. Did you try my suggestion of configuring a speed sensor input?
Did you get any reading at all from the speed sensor? You would need to tweak the different input values or do some ini computations but you should be able to get a reading. If not then you have a connection issue.
The speed sensor gave a reading in the 250 Hz range but didn't move much from there while the engine was running.
I think that 250Hz is about the maximum on an unmodified "Datalog in" input.
And what does that mean ?
See the speed sensors section of the manual:
http://www.msextra.com/doc/pdf/html/MS3 ... .3-42.html
I don't see any schematics of the PT4 circuit. Is that available ?
