Fidle & Fan control
JakeusSnakeus
Fidle & Fan control
Post by JakeusSnakeus »
Hi
I've built this circuit in the proto area will this be ok for triggering relay's etc?
Also my Fidle output doesn't appear to be working, I have a TIP120 in Q4 like below, with an inline diode on C:
I have R39 Jumper-ed and nothing in D8 or Q20 as advised above^
What am i doing wrong?
dontz125
Re: Fidle & Fan control
Post by dontz125 »
Relay control - Your GND and SPR4 are reversed; power flows from the relay on SPR4 to the transistor to ground.
FIdle - And this is why I like to use different coloured wires ... :lol: It looks like you have everything wired up, but where's your diode? That is your flyback catch diode, and should be going from the TIP120 collector to +12v (pad S12).
Take a look at the latest manual instructions; the pins selected have changed to use heavier traces. Make sure the tab on the TIP120 isn't shorting to the heat sink bar; burrs on the bar holes are infamous for causing all sorts of problems.
JakeusSnakeus
OK,
Relay control - I've swapped ground and spare 4 around - What output can i expect to see when On/Off?
Fidle - I've updated the Picture for you :P, can you elaborate on
JakeusSnakeus
Bump?
I
grom_e30
Post by grom_e30 »
your relay output will provide ground when its active. as to your idle valve have a peek here for the recommended method for putting it together inside the ecu
http://www.msextra.com/doc/pdf/html/MS2 ... .3-37.html
do you have the 3 wire valve? if so how have you got it connected up?
JakeusSnakeus
A little bit of a late reply i know lol
I've got the TIP 122 wired up on the board like the guide said.. I can now make the IDL light on the stim pulse.
I've got the pinout of the MS wired to the car like so:
Motronic Pin #---------- MS Pin # (function)----------Factory Wire Color--------Description
----------4-------------------25 (IAC1A)-----------------White/Yellow--------------Idle Control Valve #3 (open)
----------22------------------27 (IAC1B)-----------------White/Green---------------Idle Control Valve #1 (close)
grom_e30
Post by grom_e30 »
if you have done the tip120 you will only be able to control one side of the icv you will want a big 30-40 ohm 50w resistor between 1 winding and ground.
JakeusSnakeus
I see, ok..based on your reply i assume there is a way to control both sides?
grom_e30
Post by grom_e30 »
http://www.msextra.com/forums/viewtopic ... wm#p293043 few things you can build covered here.
