No RPM testing MSII
Re: No RPM testing MSII
Please post a tooth log now that you have MS2/Extra installed.
Ok I found the instructions to do a tooth log. I will do that tonight and post the results. Thank you.Matt Cramer wrote:Please post a tooth log now that you have MS2/Extra installed.
Unfortunately I am at a loss. I tried to do a tooth log but there is no reaction to the throttle pots so it can not produce a log? Not sure what to try next?
Throttle pots have no bearing on the tooth logger.
OK I can attach the log when I get home tonight. I didn't bother because when I click start and stop it says "empty file". I assume there won't be anything for you to look at?Matt Cramer wrote:Throttle pots have no bearing on the tooth logger.
In that case, there won't be anything there.
Can you check if the signal from the opto circuit is making it to pin 14 of the U1 socket with a volt meter?
I will do that. Thank you for all the help and patients.Matt Cramer wrote:In that case, there won't be anything there.
Voltage at pin 14 is 5V with Stim turned on.
If you apply 12 volts to TachSelect, does this voltage drop to zero?yesitis wrote:Voltage at pin 14 is 5V with Stim turned on.
I will try that. I am guessing that I connect the negative from the 12V battery to the heat sink and Pos to the TachSelect jumper?Matt Cramer wrote:If you apply 12 volts to TachSelect, does this voltage drop to zero?yesitis wrote:Voltage at pin 14 is 5V with Stim turned on.
OK I did the test and the voltage at pin 14 drops to zero. Is that good?
Yes, it means the circuit is working.
The bad news is you may have a faulty daughter card. These have a one year warranty; you'd want to contact the seller directly.
I purchased it from DYI AutoTune but it was more than a year ago so even though I am just building it now I'll have to buy one. Thanks for all your help.
Ouch! I just looked at the price $129.00. That's an expensive lesson.yesitis wrote:I purchased it from DYI AutoTune but it was more than a year ago so even though I am just building it now I'll have to buy one. Thanks for all your help.
Well I got the new Daughter card and with it plugged in the board it will not connect to TS? If I plug in the original board in it connects to TS fine? Did I get a second bad card? Help!
Have you loaded firmware to it? That's required.yesitis wrote:Well I got the new Daughter card and with it plugged in the board it will not connect to TS? If I plug in the original board in it connects to TS fine? Did I get a second bad card? Help!
No I have not thank you I will do that.jsmcortina wrote:Have you loaded firmware to it? That's required.yesitis wrote:Well I got the new Daughter card and with it plugged in the board it will not connect to TS? If I plug in the original board in it connects to TS fine? Did I get a second bad card? Help!
I put MS2 firmware on the daughter board and it does exactly the same thing as the last daughter card. No reaction to the RPM pots? All the other pots show a reaction when I turn them. Also the only LED that lights on the JimStim is the power LED. Is that correct? Thanks.
Check that there is not a problem with the JimStim: http://www.jbperf.com/JimStim/JimStim_v ... ml#testing. And then make sure you have adjusted the pots correctly on your MS board (assuming you are using the VR circuit).
I am set up for Hall effect and I thought I read to leave all the DIP switched off for Hall effect?racingmini_mtl wrote:Check that there is not a problem with the JimStim: http://www.jbperf.com/JimStim/JimStim_v ... ml#testing. And then make sure you have adjusted the pots correctly on your MS board (assuming you are using the VR circuit).
