I have tried searching for about an hour and came across a similar case but was fixed by soldering a missed joint. I rechecked and even resoldered joints that were the slightest bit questionable.
Nothing on the board is hot ever. All led tests check out. When I try testing the rpm signal I get a steady led light but no flashing. As I turn the rpm pots I get one blink about 1/4 of the way then the light just gets brighter. Same with the rpm fine or rpm coarse.
Is this an acceptable result? How can I test to find where the fault is? Without the chip installed, pin 13 and 14 do change voltage perfectly.
rpm test, steady light no flash
Re: rpm test, steady light no flash
Are you testing a JimStim by itself here?
Yes. I have not built the megasquirt yet. I figured it would be best to work on my soldering skills.
I know a couple joints aren't perfect but I went back and re did them the best I could and tested if they made a connection with the multimeter from the back of the board through whatever they were connecting. The only circuit board diagram I could find was not helpful in where to test "pin 1 and 3" for 3.3 volts and tracing with my eyes leads to a dead end at the 8 switches.
You have the CPU the wrong way in. The notch on the chip goes on the side closest to the edge of the board.
I'm one dumb mf. I swear I looked at that and I saw the indention and was like, "oh yea that's got to be it." My god I'm stupid. Well it works! Thanks, sorry for wasting your time.
Don't beat yourself up. We all make those types of mistakes (I know I've done some).
