trying to assemble MS2 v3.0 board.
using this tutorial:
http://www.megamanual.com/ms2/V3assemble.htm
but i am overwhelmed by the terminology and how to follow steps exactly.
will use oem sensors (+ wideband lambda)
please take a look at my car's ECU diagram (attached below).
it is full sequental injection / wasted spark distribution (semiconductors/no distributor) / crank + cam sensors
so:
no easy way for full injection with MS2? try semi sequental?
if semi seq, so i do not need S52 Cam angle (HALL) sensor/circuit?
---what steps should i follow and are must for me?:---
i have to make only step #51?#50. Next you need to make a decision. There are two input circuits for the tach signal:
a. Hall/optical...
b. for triggering off the Coil - terminals
#51. VR circuit
and if i want to use VR & Hall sensors, how can i use them both, if i have to make a selection with jumper between them?
how the hell both signals get to MS then?Do NOT install both sets of jumpers, chose one set or the other!
only 2&24 pins are for it, must i connect them (duplicate) on the same wire/pin and TunerStudio will see them?
for example: how can it see Hall if only VR circuit by jumper is selected.. totally lost..
IGNINTION:
how will i fire up my double coil if there is only one ignition pin 36 ?
if you look at my original scheme, there are two wires from ECU.
is it direct coil control?
which steps do i have to follow at #65?
?* not using IGBT
or
* wish to install the high current ignition driver
thanks a lot for reading, hope my problems are not big at all
this is my original ECU diagram Bosch Motronic 2.10.3 (Alfa Romeo 146 boxer 1.7 16v):
