Is there a way to validate or test this functionality? How would I know if it is not working correctly on my car?
Thanks in advance!
99 Miata VVT Settings
Re: 99 Miata VVT Settings
Watch to see if the measured cam angle is tracking well with the commanded cam angle.
Do I see that in the logs or is their a gauge for that?
It is in the logs, assuming (1) you're running MS3, and (2) you have put a VVT motor in this car, as a '99 motor wouldn't have VVT.
Re: 99 Miata VICS Settings
Oh Geez. Sorry, I meant VICS.
That's just an on/off output; use Output Test Mode to see if it triggers the solenoid.
