seting up an output with rpm between 2 rpms
hey all, im looking at a way to control the vanos on a 97 bmw 328i. it just uses a 12+ signal, but needs to come on at 1500rpm, and off at 5000rpm (possibly different numbers but thats not important for this). so i know ill need to setup a relay control, thats not a problem, im trying to figure it out in the programmable outputs but drawing a blank. I can get it to come on at a certain rpm, but if i set a condition to turn it off then all i get is a flash when it crosses the 2 rpm points and wont stay on between them. anyone have any tips on this setup in tunerstudio? thanks
Re: seting up an output with rpm between 2 rpms
Set it to be ON when
RPM > (low limit)
AND
RPM < (high limit)
RPM > (low limit)
AND
RPM < (high limit)
Ok I think that's how I had it set but I might have them in the opposite order, which must screw it up. I'll try that tonight on the sim. Thanks!
If you get stuck..
Ok no problem, thanks for the help!
