Have just finished building my MS2 V3.0 board, loaded MSE 3.4.0 firmware, and have installed the options for PWM Idle, and EDIS6 ign. On connecting to Tunerstudio all the gauges work, and I can adjust all inputs with the pots on my Megastim.
On the Megastim, LEDs I1 + I2 flicker, and go solid as you increase RPM. PMP comes on with them. I get no activity from "IG".
On the Mainboard, the middle LED (D15) lights until coolant temp is above ~68 degrees. Bottom LED comes on briefly if I rack the TPS. Top LED (D14) does nothing.
So, I take it this means that the Ignition output for the EDIS system is not working? There appear to be several (I found at least 4) suggested ways of wiring up the MS2 for EDIS output, but I followed this one from the Megamanual EDIS page on construction:
Obviously I am running this on the bench, connected to the Stim, rather than with the ignition module connected, but I still would have expected some activity from the IG LEDs...V3.0 main board:
DB37 pin #36 to the SAW pin (#3) on the ignition module
DB37 pin #24 to the PIP pin (#1) on the ignition module
On the V3.0 main board:
use the 'Hall sensor circuit' (step #50.a in the assembly guide) - jumper D1 and D2,
jumper OPTOIN to TACHSELECT on the bottom side of the PCB, near the DB37 connector, opposite the heat sink,
jumper TSEL to OPTOOUT on the bottom side of the PCB, near the center.
jumper JS10 to IGN (this uses the processor port for the SAW signal directly),
jumper XG1 to XG2 on the bottom side of the PCB, near the 40 pin socket,
ToGGoT
