Bought an ms2 and need some info
Hi Folks I just got an ms2extra off a lad who was using it on a ford zetec. Now it is wired for edis and for a 4 wire stepper idle motor as I now need to modify it. I want to fit a single coil driver and to install a 2 wire idle valve as what wires do I need to remove or move as I know I need to get a coil driver so any suppliers out there that supply the kit in europe.
Re: Bought an ms2 and need some info
Both pretty basic configurations covered in the manual. The V3 board is designed for a single coil driver, and there is a place on the board for one. The idle valve will likely need a high current driver transistor added.
If you think this beyond your capabilities, there are a few people in the UK who will do it for you. I'm one.
A single coil driver suggests you're going to get the trigger from a modified dizzy. Whilst this can work, it's far from the best way these days. Wasted spark using a crank trigger is a better solution.
