What does my Ms2v3.0 have? And what's it setup for?
Karathos
Post by Karathos »
Hey everyone I recently purchased an MS2v3.0. I was told that it has been set up for boost control and hall. I was hoping you could look at the pics and tell me what I actually have.
I need to be able to run vr on a modified distributor, and a single coil.
Unless this is already setup for the 36-1 wheel I have.
I have done a lot of mega manual reading. But I feel experience is always a better eye than just hoping you read the manual correctly
http://s164.photobucket.com/user/Karathoss/library/Mobile%20Uploads
Hopefully the link/pictures work. I'm not really sure
grom_e30
Re: What does my Ms2v3.0 have? And what's it setup for?
Post by grom_e30 »
the tach input appears to be jumper'd for the opto input(coil negative triggering) fuel only, you will need to make some changes for it to work with a vr sensor just soldering a few jumper wires, see here http://www.msextra.com/doc/pdf/html/MS2 ... .4-61.html
it also looks like its jumper'd to run a single high voltage coil using js10 as well as a stepper idle control valve and i think js11 is jumper'd for a pwm style output boost control maybe connected to spare3 pin in the harness.
