Hey everyone I recently purchased an MS2v3.0. I was told that it has been set up for boost control and hall. I was hoping you could look at the pics and tell me what I actually have.
I need to be able to run vr on a modified distributor, and a single coil.
Unless this is already setup for the 36-1 wheel I have.
I have done a lot of mega manual reading. But I feel experience is always a better eye than just hoping you read the manual correctly
http://s164.photobucket.com/user/Karathoss/library/Mobile%20Uploads
Hopefully the link/pictures work. I'm not really sure
What does my Ms2v3.0 have? And what's it setup for?
Re: What does my Ms2v3.0 have? And what's it setup for?
the tach input appears to be jumper'd for the opto input(coil negative triggering) fuel only, you will need to make some changes for it to work with a vr sensor just soldering a few jumper wires, see here http://www.msextra.com/doc/pdf/html/MS2 ... .4-61.html
it also looks like its jumper'd to run a single high voltage coil using js10 as well as a stepper idle control valve and i think js11 is jumper'd for a pwm style output boost control maybe connected to spare3 pin in the harness.
