Hello,
I have internal knock module on MS3, i test advance retarding.
I test with 36-1 wheel on my press dril in toothed wheel mode.
I test EDIS and Basic trigger mode with Megastim, and i never see advance retard.
I can see variation for the knock input in TS gauge but no Knock Retard, always 0.0 deg in the gauge.
I am several hours of reading and research to find a solution, but for the moment its does not work.
Can you help me?
Knock advance retard probleme.
Re: Knock advance retard probleme.
Is that possible to test a knock sensor retard advance signal with a bench tests ?
Yes or no?
Yes or no?
It's going to be tough - you have to spoof the right frequency at the right crank timing.
Ok,
Thanks for you reply.
