Morning chaps,
I did the following mods to my MSII to go with a HE sensor but I now want to change to using VR since I've gone for a new triggerwheel setup that has much finer teeth...
TACHSELECT to XG1
TACHIN to pin24
C30(top) to S12C to JS9
TSEL to OPTOOUT
1k resistor @R12
Am I better off undoing all of the above or can what I have be used for VR?
Cheers!
Modding V3 board with HE to use VR?
Re: Modding V3 board with HE to use VR?
Took me a minute to figure out what you meant by an HE sensor - I couldn't figure out why you were trying to use High Explosives. Gives new meaning to "blown engine" ...
Wire it up according to the manual for a VR sensor; adjust the pots for a hall sensor. Stick C30 in the H1 pads.
Yeah, I was trying to relate it to GM's HEI dizzys...
