Hello,
i have an old MS1 2.2 board i run on EXTRA and all seems find, i brought a box of bits, full of components and boards ect, BUT it also has a an MS2 chip in it....
now would i see any benefit fitting this to my 2.2 board and how?
cheers
Andy
MS2 chip on a 2.2 board?
Re: MS2 chip on a 2.2 board?
Heaps of benefit in the upgrade. I have been running a MS2 on a V2.2 for a couple of years now. I actually used the old B&G instructions to do mine. http://www.megamanual.com/ms2/install.htm The ignition jumper they show is just a straight connection from JS10. I didn't go that way because I used led spark outs on mine with an extra db9 fitted to the case for those to come out and some programmable outputs as well.
cool cheers i'll have a look at that, i'm running EDIS as the mo, do you direct fire then?
Cheers
Andy
Cheers
Andy
Originally 4 x VB921 drivers doing wasted spark on my v8. These days I just use 1 VB921, single coil and a locked distributor but kept the crank sensor for tach in.
got it,
looking at that link its mentions a daughter board... unsure if i have one of those, just the MS2 chip....
The MS2 processor is a daughter board with lots on it. If just a single chip, it's an MS1.
