1) what is the best circuit build for EDIS6 : VR or Hall/opto ?
2) rising edge and going high for Hall/opto circuit, and what for VR circuit ? falling edge and going high ? i"m much confused about this .
sorry for my bad English
Didier
Opto circuit or VR circuit what is the best for EDIS6 ?
Re: Opto circuit or VR circuit what is the best for EDIS6 ?
its advised to use the vr input but set it up as if the edis signal was a hall sensor.
OK, so : VR circuit , and rising edge , and going high , correct ?
http://www.msextra.com/doc/pdf/html/MS2 ... 4-113.html
http://www.msextra.com/doc/pdf/html/MS2 ... 4-114.html
