I am Bill Biggs from Temple, Tx. I have a MS1/Extra that I plan to use on a 1999 Ford 4.6 DOHC with COPs in a 1953 Studebaker pickup.
There have been changes to the board and I need to ask what I need to change or change back to original.
Here is a list of the changes I can identify:
Front of board
R38 has been removed and a jumper installed across the outer pins.
R37 has been removed and jumpered and replaced with a bip373 with leg 3 soldered to the jumper, leg one jumpered to the top of R26 with a 330 ohm resistor inline, leg 2 jumpered to SPR4
R57 not installed
D1 and D2 are removed
C12 and C30 are removed
Back of board
SP4 jjumpered to a pin on .db37
IGBT in jumped to top of R29 W/330 ohm resistor inline
R13 jumped to R12
TACHSELECT to bottom of C30 which is removed
I plan to add a DB 15 for my coil outputs[
help with used MS/Extra V3.0
Re: help with used MS/Extra V3.0
New photos
Better quality pictures, please.
