Firmware mismatch
Firmware mismatch
Well this cant be good. I just assembled an ms3.0 from DIYautotune and uploaded the 1.4.1 firmware (freshly downloaded). It seemed to be successful but upon opening tuner studio i get confronted with this:
Your MegaSquirt is using firmware:
'MS333333333elease 20160421 12:211111111 JSM/KC ********'
Project Serial signature: 'MS3 Format 0524.05 '
MegaSquirt Serial signature: 'MS3 Format 0524.0555'
I have tried 2 different USB cables with win10 and Linux. It all results in corrupt firmware. So something is wrong.
Where do i go from here?
Re: Firmware mismatch
Even though you tried two different cables, that still points to serial corruption somehow.
Also, are you certain the PS you are using for MS is up to it? I had one which seems to run a Stim and MS OK on test - but caused problems when trying to load new software.
Nothing wrong there.
James. Those pins are supposed to be shorted?! That seems really odd.
Keep pluggin at this.
All voltages doubled checked as per 13.5 in the MS3X/V3.0 manual, I measure 4.88v. swapped power supplies. Was using 1.5A wall wart and now 70A computer PSU. No difference...
After flashing this thing a couple more times I notice it doesnt always flash nicely. Using debug 3 i get:
Record 4353 results in Status code 0xe0. Is this normal? Then at the end it aborts. It doesnt seem to do this repeatable. Only maybe, half the time.
Code: Select all
Sending record 4352:7ca780
TX: c1 7c a7 80
TX: e2 cd 72 b8 39 7d f8 39 7e 7c 39 7d 18 87 fc 33
RX: e0 00 3e
Sending record 4353:7ca790
TX: c1 7c a7 90
TX: a3 87 c4 0f b7 46 cc ff ff eb e2 22 ac 89 00 35
RX: e0 e0 e0
Status code 0xe0
Prompt was α
Sending record 4354:7ca7a0
TX: c1 7c a7 a0
TX: ac b1 27 06 08 8e 00 0f 23 ec b7 54 59 b7 45 ec
RX: e0 00 3e
Sending record 4355:7ca7b0
TX: c1 7c a7 b0
TX: e2 cd 72 b8 37 a7 f8 37 a8 7c 37 a7 20 58 f6 2c
RX: e0 00 3e
Sending record 4356:7ca7c0
TX: c1 7c a7 c0
TX: 11 c1 05 26 4c fe 33 a3 b7 54 87 c4 f0 8c 00 20
RX: e0 00 3e
Sending record 4357:7ca7d0
TX: c1 7c a7 d0
TX: 26 3f b7 54 87 c4 0f 59 b7 45 ec e2 cd 72 b8 39
RX: e0 00 3e
Sending record 4358:7ca7e0
TX: c1 7c a7 e0
TX: 7d f8 39 7e 7c 39 7d 18 87 fc 33 a3 87 c4 0f b7
RX: e0 00 3e
Sending record 4359:7ca7f0
TX: c1 7c a7 f0
TX: 46 cc ff ff eb e2 22 ac 89 00 35 ac b1 27 06 08
RX: 3e 00 3e
Error code 0x3e
Aborting - send_block()
Have tried a pure RS232 (DB9) connection, no USB adapters or cables?
Well bill oldschool wins again here.
Usb>Serial interface works just fine. I finally got the firmeware on the daughterboard.
So using serial it seems to work just fine. Near i can for now.
but USB is still dead. even with correct firmware TS reports a mismatch with a garbled version number. bummer.
Don't give up on USB completely, it can work and is more convenient, since RS232 isn't so common anymore. I have just found that the USB was more fussy, wouldn't work with some laptops, but has been fine with my latest. There were no changes to the MS or cable, it must have been something with the computers or the way I installed the drivers.
