Settings error,
grom_e30
Re: Settings error,
Post by grom_e30 »
turn the noise filtering off, make sure the pots r52 & r56 are both full ccw give them 7 turns to confirm this while you are doing this make sure jp1 is across 1&2 and that j1 is set to 3&4.
usually bmw vr sensors the black wire is the vr+ and the yellow is the vr-
BlackBird_SR71
Re: Settings error,
Post by BlackBird_SR71 »
Did you order that new Crank sensor that you mentioned in your other thread?
grannyknot
Re: Settings error,
Post by grannyknot »
I did install a new crank sensor and tried it with the polarity reversed, no go, but I did get it running :yeah!: :yeah!: A resistor was needed between the crank sensor wire and the MS ECU. The stock bmw IAC valve is causing a very high idle so will install a stepper IAC valve from a 4.0L jeep instead.
Thank you for everyone's help
MS2 PCB v3.57 MSrelay board, LC-2 Innovate O2
BMW M6/s38b35 w/6 ITBs
BlackBird_SR71
Re: Settings error,
Good job!! Now on to the Tuning!! Image
