Hi guy's i have a problem to set the good voltage on R54 (2.5v).
I have just finish to built my MS3X and test them with a 12v with 1A (not justim),
So i would know if just plug the MS to 12v is sufficient to adjust the voltage with R56 or if i need to put the Hall sensor (that i will use) to have voltage on R54.
Because i don't have issue on R54 with just 12V.
Thanks for your help.
How to have 2.5v on R54 (adjusting R56)
Re: How to have 2.5v on R54 (adjusting R56)
There should be no problem doing that.
Effectively at final it run perfectly. Thanks
