I posted in MS3 general and shortly after realized it shouldve been posted here. Sorry mods.
Okay so, Miata !UZ swap.
Pic of my board.
I'm getting a 1.5v drop from the battery to U5, S12C and the left pin of D9. Using a stim board and a 9v.
MS3X V3.57
Re: MS3X V3.57
There's a couple diodes in the way. Voltage drops a little across each diode.
Re: MS3X V3.57
Also, that's a V3.0; trying to configure it using the instructions for a V3.57 will have you scratching your head.
Re: MS3X V3.57
As long as its nothing I should worry about. I just read that it should be the same as the battery voltage.There's a couple diodes in the way. Voltage drops a little across each diode.
Ahh, man. I couldve sworn I ordered a 3.57 but it looks like I didnt. Thank you. That will likely clear up a lot of confusion.Also, that's a V3.0; trying to configure it using the instructions for a V3.57 will have you scratching your head.
