All tests (and I mean all, even the stim tests(bought pre-made)) check out properly WITH THE PROCESSOR OUT. The loopback test works great on the cable, and on the bare socket (powered up, jumped pins 12-13), but the minute I install the processor...I get no power coming out of U5, or anywhere else that uses VCC/VREF power. There IS battery power (from stim) on pin 1 of U5 though, and all places that read straight from the stim get proper batt power. I even checked for power at the MAX232 chip, and with the main processor out, pin 16 gets VCC. The minute that processor goes back in...dead as a doornail.Matt Cramer wrote:To check for a short in the Megasquirt PCB, power up the Megasquirt on a Stimulator or on the car and check the following points for voltage with a multimeter.
You should find the same voltage as the battery voltage on the following points: the small hole to the right of the larger three holes marked X11, X12, and X13, the top (non-banded) end of D20, the left leg of U5, and the left (banded) end of D12.
You should have 5 volts at the following points: the right (non-banded) end of D12, the right leg of U5, and pins 1, 20, and 31 of the CPU.
With the processor out, all voltages read properly from the pots on the stim (but no LEDs go on), but again...the minute I install that processor...nothing.
So, I'm thinking I blew up the processor. Would that be a safe bet? It was working great after I built it, but I just HAD to reflash...sigh.
