Afterward I verified that the distributor was outputting a valid crank signal by swapping the cam and crank pin at the distributor. I got a healthy crank signal through the cam input. Which narrows it down to either a build error or something got fried when I had my distributor wired wrong.Using the MS-III V3.0 or V3.57 ECU with MS3X for full sequential
The MS3 manual generally favors the VR input, so we’ll be using that.
Place the JP1 jumper in the 1-2 position for a V3.57. For a V3.0, jumper TachSelect to VRIN.
Place the J1 jumper in the 3-4 position for a V3.57. For a V3.0, jumper TSEL to VROUT.
Put a 1K resistor in the R57 slot on a V3.57. For a V3.0, run a 1K resistor from S12 to TachSelect. (Or you can use a 1K pull up in the wiring from a 12 volt source to pin 24 of the main board.)
The second trigger input also needs a pull-up. Install JP7.
TunerStudio settings (Sequential coil on plug and / or sequential fuel): All are under Ignition Settings -> Ignition Options / Wheel Decoder.
Spark mode: Toothed Wheel
Ignition input capture: Rising Edge
Spark output will depend on what output setup you’re using. QuadSparks use Going High / Inverted; so do OEM SR20DET ignition modules. Getting this setting wrong can damage the ignition module and/or coils. If the ignition module or coils get hot with the key on and the engine off, turn the key off immediately and select the opposite output setting.
Trigger wheel arrangement: Dual wheel with missing tooth
Trigger wheel teeth: 12
Missing Teeth: 1
Tooth #1 angle: 345 (This varies slightly between individual engines. Check with a timing light and adjust as needed.)
Wheel speed: Crank wheel
Second trigger active on: Poll Level
I'm currently waiting on a jimstim v1.5 and spare components coming in on Thursday. I ordered all of the components for the Vr circuit per page 199 of the MS3X hardware manual, although DIYauto does not sell D24. So I can bench test the ecu and diagnose the circuit. I have chipped ecus and built simple circuit boards in the past. But this would be my first time diagnosing a circuit on a pcb, yet alone this complex, and I would like some insight on how to test it.
