Why in the world would I have had 5V going to the banded side of D8 (D8 is not fitted) through a 1k resistor?
I must have done this a long time ago for something but I'm pulling it if no one can figure out what it may be for!
Thanks as always!
5V -> 1k -> D8
Re: 5V -> 1k -> D8
V3.0 board?
Sounds like you've turned "FIDLE" into a 0-5V output.
Re: 5V -> 1k -> D8
Hmmm... yes I'm using FIdle for Fuel Pump PWM control (signal only, not load) using one of Jean's PWM Frequency Converter boards. I am feeding the board with 12V from S12, and 5V from the 5V pin near the proto board. Did I still need that 5V coming in through D8?
Re: 5V -> 1k -> D8
I figured it out - it has something to do with the way the fuel pump works, it isn't a grounding PWM signal so I needed a pull-up. I found the thread on Jean's board where he got me straightened out.
I have to start writing this stuff down.
Thanks for your time, James.
