u3 orination
u3 orination
hello new to ms3 working on my board installing u3 chip there is no dot or notch on it. the top of the chip has a step down side on it which direction does this go in relation to the board, thanks for your time
Re: u3 orination
should be like these.
Cheers Luke
Cheers Luke
Re: u3 orination
yes the dot is not so visial but it clearly has the same step or line down one side i placed it in the board with the step or line towards the 40 pin base. i believe this to be correct. thanks for quick reply
Re: u3 orination
in this position it puts the numbering id faceing the same as the other chips on the board hope this is correct!
Re: u3 orination
Notwithstanding any other markings, the 'dot' denotes pin 1 and the chip must be installed that way!
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Re: u3 orination
thanks to all for the help its in stalled moveing on to the next phase thanks again to all!
