ms3x cam voltage adjustment
hello all had quick replys and help here im a newb question i have ia when ajusting voltage at r11 of ms3x card for 2.5 volts for ls1 cam i turned 52 all the way counter clock wise than started tuturn r11 cock wise with voltage being measured and got to 2.4 volts and that was it. no matter how many more turns that is max reading so am i ok or do i have a problem or cause stim jim only puts out 10.28 volts or so not a true 12 volts is this the cause thanks!
