testing ms3x
moho9
testing ms3x
Post by moho9 »
testing my ms3x and haveing ingition proplems question is on jimstim running 2.04 i have my cam wheel settings from manual using jumpers for hall effect its 24-1 wheel pattern do i need the stim pull up 5v or 12 v? not sure if my board is built wrong by me or if my testing set up is wrong thanks
Rick Finsta
Re: testing ms3x
Post by Rick Finsta »
IIRC, It depends on which inputs you are using. I'm using the "standard" inputs and mine (crank and cam) are both 12V pullup on the stim.
moho9
Re: testing ms3x
Post by moho9 »
thanks rick will give that a try
