testing ms3x
testing ms3x
testing my ms3x and haveing ingition proplems question is on jimstim running 2.04 i have my cam wheel settings from manual using jumpers for hall effect its 24-1 wheel pattern do i need the stim pull up 5v or 12 v? not sure if my board is built wrong by me or if my testing set up is wrong thanks
Re: testing ms3x
IIRC, It depends on which inputs you are using. I'm using the "standard" inputs and mine (crank and cam) are both 12V pullup on the stim.
Re: testing ms3x
thanks rick will give that a try
