I see my latest MS2 3.0 kit comes with FDPF3860T FET's for the injector drivers Q1 and Q5.
Are these "avalanche rated" ? There is a note on the schematic that the active flyback clamp circuitry can be omitted if so.
MS2 3.0 FETS
MS2 3.0 FETS
67 Chevelle, LSX V8 engine, EFI., cuppa 80's TPI projects....I like wires.
Re: MS2 3.0 FETS
The Avalanche information is shown on the datasheet. https://www.fairchildsemi.com/datasheet ... F3860T.pdf
Cheers Luke
Cheers Luke
Re: MS2 3.0 FETS
Yes and its given as 278mj single pulse or 3.4mj repetitive. Whats that mean ? Is that enough ? You hurt your what ?
Re: MS2 3.0 FETS
Seems like there are 2 questions here.
1. Is the FDPF3860T an equivalent replacement for the IRFIZ34?, Yes seems fine.
2. Is it a good idea to omit the Active Clamp components?, No I would not omit the clamp using either the original or this mosfet. What is to be gained by reducing protection to the mosfet?
Cheers Luke
Cheers Luke
