Am repairing an MS2 V3. At the same time, am changing it from B&G to Extra Code. It has the VR input missing, but has been running EDIS using the opto input just fine for years.
Question is, do I have to mod the opto input to the Extra schematic, or will it be OK staying as is with the B&G version for EDIS?
Tach input.
Tach input.
Re: Tach input.
You can use the same hardware configuration as long as you keep the same ignition input capture setting you were using before.
Re: Tach input.
Thanks Matt. Perhaps I should change it so as not to confuse anyone somewhere down the line?Matt Cramer wrote:You can use the same hardware configuration as long as you keep the same ignition input capture setting you were using before.
