burt cable
burt cable
need a little help does anyone know where i can get a ribbon cable that goes between the ms3 card and the ms3x expansion card got the edge of mine with soldering iron thanks tried dyi but they can not help looking for the i believe the 34 pin cable thanks again
Re: burt cable
ok got on line found what i think is needed from mouser electronic 34 row 6 in long with 34 socket on each end will post if correct
Re: burt cable
This should also work. https://www.digikey.com/product-detail/ ... ND/1218521
Re: burt cable
thanks matt comparing the two together i believe we are good to go , but the di-key price is much better by far! hopefully no one else will pull a stunt like i did !
Re: burt cable
well happy to report the cable is a go . but if i had not found this before matt came up with his find i would go with his choice and save 7 dollars shipping was fast through.
