hi all
First post new here
this is my 2nd MS-3 setup first was LS1 which worked 100%
then on the 2nd one also MS-3 was onto a nissan SR20DE which changing to DET, the wiring was all set up and unit was working then keyed off and then back on, nothing happened MS is dead, maybe somewhere the CAS set up was wrong but we think blown Daughterboard card or expansion board (not Happy)
will have to order new
looking on internet came across this pic of a SR20DET CAS wired up, like to know if this is correct
as they use TP4 (31) and not the Cam Sensor (32) MS3X wiring
Clive
Nissan SR20DET CAS wiring
