Can Internal Knock module output a Dash LED for Knock events
Danbob
Post by Danbob »
Hi, A friend of mine runs an "EMU" ECU which can be set to light an LED on the dash every time it detects a knock event.
I have an MS3X with the internal knock module, is there any way to have this setup light an LED when knock is detected?
Dan
grom_e30
Re: Can Internal Knock module output a Dash LED for Knock ev
Post by grom_e30 »
you would have to do it as a programmable on/off output, and use something like, if knock retard is > 0 it will put the light on.
Danbob
Post by Danbob »
Thanks, found it in programmable inputs looks like that should work!
