Hi, I'm almost finished making my harness to install my MS3X.
I want to use an output to light the OEM check engine light (ground to light). What is the best output to use for this?
I have MS3X board, with knock module installed. most outputs are unused.
I was going to use FIDLE, can this output be programmed to output CEL?
Is it better to keep FIDLE for something like water injection and use a lower current output for check engine lamp?
Dan
What is the best output to use for Check Engine Light? (MS3X
Re: What is the best output to use for Check Engine Light? (
Any of the outputs that are selectable for CEL duties are the best ones to use.
Tha Daily: 2005 Chevy Blazer
FIDLE isn't a particularly high current output. It will work fine here.
Ok thanks.
That's one more down then, only vss, external air temp and a couple of others to figure out now
Cheers
Cheers
