Vane Hall Effect Phassing
I am checking the phasing on my modified Bosch Hall effect dizzy. The manual does a fine job of describing the process for a recluctor based pickup, but make no mention of a vane type sensor. The question is: is the trigger angle determined by the center of the window or the trailing edge of the vane? Signal goes high in a window.
Re: Vane Hall Effect Phassing
Is this MS1, MS2, or MS3?
I'm not sure about MS1 but on MS2 & 3, it's either the beginning or end of the window depending on the hardware configuration and trigger input polarity selection under ignition options.
Eric Law
Thanks! The edge was my guess, but wanted confirmation.
