RPM not synced. but works for 2 seconds
Loggato
Post by Loggato »
hello. to start, this is my first time setting up a management system with megasquirt, but i have worked with a car that already had it installed.
I'm using MSII with the 3.57 board, and running EDIS ignition on a V8 engine. I'm using a Ford 36-1 wheel, with a standard Ford VR pickup.
To start, I had troubles finding out how to set up the 3.57 board to work with EDIS, if someone has a proven method, please let me know!
the issue: I'm getting rpm signal for about 2 seconds, and then it throws an "RPM not synced" code. I'm glad that it's at least getting a signal for a short period of time, but would like it to get a constant signal. perhaps someone can explain what exactly is happening. picture attached.
Thanks in advance!
slow_hemi6
Re: RPM not synced. but works for 2 seconds
Post by slow_hemi6 »
If you are using the extra code this is the manual section. http://www.msextra.com/doc/pdf/html/MS2 ... 4-110.html
The picture shows too little.
:msq:
Use the forum help page if you don't know how to post these files.
Cheers Luke
