Over Heating Issue?
Over Heating Issue?
I live in Sacramento, CA, where it can get hot in the Summer. I have a 72 TR6 roadster and MS3x controls the fuel injection and ignition through EDIS. It is also supercharged with an Eaton M62 Gen II. No air conditioning on older British converables, so on 105 degree F days the MS3 sitting above passengers feet is probably 105F. While logging data to Tuner Studio I have had no problems for the last three years. But twice now, when I finally ventured out to drive in that hot hot weather, I have lost the connection between the PC and MS3. MS3 continues to control the car excellently, only the connection to the PC fully drops. In the evening when it cooled down, the connection is back to normal. IAT runs about130F underhood and MAT measured between supercharger and the valves in the airbox reads about 145F in typical driving in hot hot conditions. I am thinking that temps inside the MS3 box, or PC notebook temps get too high and "something" causes a halt to data transfer. I notice that the MS3 box is airtight- should it have some air vents? Internal fans come on in the PC when internals heat up a bit. Does the MS3 need a small cooling fan and vent holes? Anyone else have these issues? Attached is log file, and you can see red lines where it dropped once, returned, then dropped out fully at end.
Re: Over Heating Issue?
Are you using the USB connection or a built in serial port?
The box typically shouldn't need cooling, unless you bolted it directly to the supercharger.
Thanks for the reply. Am using a heavy duty 2ft long USB cable. MS3 attached to a shelf above passengers feet. Several drives recently in cooler weather, records data fine when not overly hot weather.
I certainly would be suspicious of that. Everything I have read seems to discourage the use of usb cables. Particularly long ones!72bluetr6 wrote:Am using a heavy duty 2ft long USB cable.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Easy to try another cable. Looks like I'ill have to wait awhile though - wont get hot enough here for awhile.
FYI: My USB cable is 4' long, no problems. Not much over 80F around the MS, though.
Bill, yes, the cable I have has worked fine for about five years now. It is only when temps get really hot here that I have had this issue. - And I rarely drive when it is hot hot, only I wanted to check out car functions at high ambient temps. (Car does fine- even a long idle and accelerations with supercharger working max. boost -but I need a wet towel around my neck!) I have to rule out my notebook port cutting out, too.
