RPM Not Synced- Help with Composite Log Reading
kenjfox
Post by kenjfox »
Hi all,
I have a 99 miata on MS-3/3x 1.5.0. 36-2 wheel. I'm getting output from the logger for both crank and cam, but the log output doesn't make sense to me. For the crank, I would expect to see many short spikes between one 3x the height, right? I'm getting a flatline between spikes. Any help would be appreciated.
billr
Re: RPM Not Synced- Help with Composite Log Reading
Post by billr »
Post a "tooth log".
grom_e30
Post by grom_e30 »
green marks are the cam signal, blue should be the crank.
crank signal is missing from the log you appear to see only 1 tooth on the crank
whittlebeast
Post by whittlebeast »
You are not getting any crank signal. Cam looks fine.
AW
