Help: ID this M$2Extra Config
Postby FubarI33t » Tue Oct 31, 2017 7:09 am
Got this unit as a hand me down. was told one or both ign drivers are shot. got those plus others ready to order. But first. No INFO came with it such as What engine, Ign Setup Used or really anything at all. so. Here's a few pics. and I hope we can get it ID'ed and reset-up for what I want it used for.
My wanted Config: Datsun L18(4 cylinder Single OHC) Ford EDIS, 2 stage Injectors(8 total) Map AND TPS inputs along with the standard temp sensor. Fan control is stand alone. No Idle control needed. Wasted spark. Batch fire primary injectors. and if we can seq the secondaries sure. if not Batch fire them as well. Hope to fire them biased on Load and RPM.
Better To Burpp And Taste It, Then Fart And Waste It.
74 Dato 620.
FubarI33t
Re: Help: ID this M$2Extra Config
Postby FubarI33t » Tue Oct 31, 2017 7:10 am
Srry for the large pics. but it does show location well lol
74 Dato 620.
FubarI33t
Postby FubarI33t » Tue Oct 31, 2017 7:23 am
as soon as I get a serial cable I can connect and maybe get some more info for whats stored on it.
74 Dato 620.
FubarI33t
Postby billr » Thu Nov 09, 2017 7:27 am
Still no bites on this one? The pictures are simply too poor in quality/format for me to even try guessing.
billr
Postby DaveEFI » Thu Nov 09, 2017 7:36 am
If you are using EDIS, no need to replace the faulty high current ignition drivers. As those are in the EDIS module.
DaveEFI
Return to Board assembly and testing
