knock module install
moho9
Post by moho9 »
hello all I am installing the knock module to my ms3x card. my question is that i saw a video on u tube that showed the install using removable sock pins for the attachment to the top of the ms3x card allowing simple removal of the knock sencer card to excess the under neith
... just pull it off . Does any one have the source for these socket pins i believe they are called i have searched and the amount of electronic gear that i wade through was staggering simply because i do not know what they are specifically called . thanks for any and all help
MegaMicra
Re: knock module install
Post by MegaMicra »
They're called pcb header pins or sockets, depending whether you want male or female.
Sent from my WAS-LX1A using Tapatalk
moho9
Post by moho9 »
thanks will look for them
TurboBob
Post by TurboBob »
where are you located, perhaps someone can recommend a source.
Bob
