MS2 hall effect Circuit for SR20 dizzy
Berto24
Post by Berto24 »
Hi guys I have a ms2 3.0v with the following hall circuit Tach Select to Xg1, Optoin to 5v proto area with 1k resistor and Tsel to opto out is this ok for a sr20 dizzy? or this circuit instead; Tach Select to Optoin , Tsel to Opto out andConnect S12 to TachSelect using a 1K resistor.
prof315
Re: MS2 hall effect Circuit for SR20 dizzy
Post by prof315 »
Neither :RTFM: VR input is the " generic tach input" for everything except coil negative fuel only triggering.
Support the developers!
