Introducing RealDash
Re: Introducing RealDash
Postby janimm » Thu Apr 27, 2017 5:34 am
Want to have RealDash user interface on your native language? The localization support is coming in next update.
Previously we have used professional translation services, but with RealDash we feel that only gearheads are able to translate it correctly.
Do you want to help us to translate RealDash into your native language? Send me a private message, or email to contact@napko.fi. We will reward finished translation with a RealDash premium package, containing full version and all current premium dashboards. We may even throw some upcoming premium dashboards into bunch too :). But before throwing yourself into this, please be prepared that translation is not a small task, and will take quite a bit of your time.
Hungarian, Turkish, Czech and French are already in progress and will be included in next release.
janimm
Postby janimm » Fri Apr 28, 2017 7:50 am
RosslandToy wrote:This might have been covered.. Does this work with a MS1 or just the MS2/3?
The app reconizes the ecu with a USB connection, but does not actually read any readings. I think I might be missing a step in the set up.. Any guides for set up?
Check the following:
- Serial baud rate is set to 9600
- You are using latest extra code
- Try imporing your ini file from connection settings. We have been using ini file 'ms1-extra029y4a.ini' for testing.
janimm
Postby benckj » Sat Apr 29, 2017 12:30 pm
After several failed attempts to download RealDash onto my new head unit I gave up and paid for another subscription to Shadowdash. Kept getting a message that my device was not compatible or supported by RD. Using Adroid 5.1.1
Jim
MSPNP v2 with 3.57 firmware
Toyota MR2 98 3sgte
TD05sl2-18g (billet wheel & high flow turbine)
A2W IC
WI with 50/50 meth/water
benckj
Postby janimm » Sat Apr 29, 2017 12:51 pm
Sorry to hear that you have had problems. There are some fixes for Google Play "Device not compatible" problem if you still want to google around. You can also get some more information about why your device is listed as incompatible by going to play store with desktop web browser.
I can try to help you with this issue. Send me email to contact@napko.fi. And if you feel that you are done tweaking with it I completely understand.
janimm
Postby benckj » Sat Apr 29, 2017 1:09 pm
I need to play around with it some more. I'm not really up to speed with Droid and Google play apps as we use iPhones through work. Thank you for the offer and I will be in touch once I complete some homework.
Jim
Toyota MR2 98 3sgte
A2W IC
benckj
Postby acedeuce802 » Wed May 31, 2017 7:23 am
Are there any differences in stability or speed between the Android and Windows 10 version? I have a dual boot Android/Win10 tablet and am trying to decide between which OS to use before buying the full version on one of them. Win10 would be nice because I can switch to TunerStudio quickly for tuning, but if there's any real advantage to the Android OS, then it's just a few minutes to reboot to the other OS.
acedeuce802
Postby janimm » Wed May 31, 2017 7:41 am
Good question. There "should" not be any difference, but in real life Android has been more robust in long running bluetooth connections. There are also some features that are not available in Windows version, mainly the automatic boot on charger events and "Currently Playing" feature. Also the upcoming Live Data Streaming feature will come for Android first.
Usually apps run somewhat slower on Windows (on otherwise comparable devices), but that is not always true. Keeping Windows graphics drivers up to date helps, but not many people do that since they are not included in normal Windows updates.
Since you can run/try RealDash without paying first you should try how each works for you. And full version activation for both platforms won't break a bank :D
janimm
Postby roolis » Sun Jun 18, 2017 1:25 pm
Hello guys,i have connected RealDash app to my friends Supra MS2 via bluetooth with no problem,i am using same MS2,but cant get it working,i set everything in setup wizard,but when dash comes up,it writes GPS is not available at this moment and the its trying to connect to bluetooth adapter several times with no luch,just writing "connecting to megasquirt",any help?i am using Samsung Tab2 for dash with 4.0.1 firmware
roolis
Postby janimm » Tue Jun 20, 2017 2:45 am
roolis wrote:Hello guys,i have connected RealDash app to my friends Supra MS2 via bluetooth with no problem,i am using same MS2,but cant get it working,i set everything in setup wizard,but when dash comes up,it writes GPS is not available at this moment and the its trying to connect to bluetooth adapter several times with no luch,just writing "connecting to megasquirt",any help?i am using Samsung Tab2 for dash with 4.0.1 firmware
I assume you mean your Android tablet OS version is 4.0.1 (not to confuse it to Megasquirt firmware version). That may be the problem, since RealDash is officially supported from Android API level 16 onwards (4.1.x). If you like, you can use the "Serial debugging" feature and send the log file to us for analysis. For instructions, see our FAQ at http://www.realdash.net/faq.html. Search for "debug" word on FAQ page.
Also, you may want to try importing your Megasquirt ini-file into connection settings. When correct ini file is imported, RealDash uses different (faster) communication with Megasquirt.
janimm
Postby JoseMiguel » Wed Jun 21, 2017 5:46 am
Hello
First of all, thanks for an excellent piece of software. I have been using RealDash on many Android devices and I think it is just great.
I saw on your facebook page the new "pole position" premium dash which I think is great for our racecars. I have never downloaded a premium dash before. When I try to "unlock" it, I get a message saying that "Store services are unavailable"
Why is this?
Currently running on OnePlus 3T with latest OxygenOS revision based on Android 7.1.1
JoseMiguel
Postby janimm » Wed Jun 21, 2017 6:00 am
JoseMiguel wrote:Hello
Why is this?
For whatever reason RealDash cannot connect with Google Play services. please try the following:
* Go to your device Settings->Apps and look for two apps: "Google Play Services" and "Google Play Store"
* For each of those apps select "Storage->Clear Data" and "Clear Cache"
* Open Google Play Store app and seach for RealDash.
* The open RealDash and try unlocking the dashboard again.
Hope this helps.
janimm
Postby JoseMiguel » Wed Jun 21, 2017 6:12 am
Yeap, worked perfectly and I got the dash :)
ThanksImage
Sent from my ONEPLUS A3000 using Tapatalk
JoseMiguel
Postby janimm » Wed Jun 21, 2017 7:46 am
Great. Enjoy! This new dashboard is my current favorite too 8)
janimm
Postby janimm » Fri Aug 11, 2017 6:14 am
We just released RealDash version 1.2.4. The unfortunate bug that prevented the 'ECU Specific' input values from working is now fixed. We also published our new promo video:
https://youtu.be/9th1FSEi1LY
and then just for fun:
https://youtu.be/6HmErFXNnL8
Let me know if you have any suggestions to make RealDash better.
janimm
Previous
Return to Other tuning /logging software
