When the background doesn't clean up the old dash, does it clean up a split second later on it's own or do you need to swipe?One issue I'm having (other than artifacts when I rotate)
I have had this issue during development, but it is not happening on any my devices.
What version Android are you running?
It is supposed to on the 1st 3 dashboards. Dash number 4 is always generated from the ini file at this point, so it doesn't remember.I can select the gauge and change it but it doesn't always change on the display and it never saves any of the changes. Is it suppose to?
That is good. earlier I had the 1st screen a hybrid between a gauge cluster and TextViews for displaying information, but after weeks of optimizing the gauge painting, I reached a point where it used less CPU to paint the Gauges clusters than basic TextViews, so I enhanced the gauge cluster some more to support the gaps to get rid of the standard widgets.and very easy on the battery.
There is no load dash dialog yet. You need to edit the .dash files in the project folders.Do you have any additional phone-scale dashes setup to try?
None of the dashboards in the installer are really catering toward small resolution screens yet either.
Something I was also considering is to have it load some different default dashboards if resolution is under say 800x600. It will scale the dashboards down now, but it isn't easy to read them.
I'm thinking on lower resolution screens there should be at least 1 page that has a more basic display with fewer and larger gauges.
