Introducing Shadow Dash MS
Re: Introducing Shadow Dash MS
Postby Speedy_G » Wed Apr 27, 2016 10:58 am
i found a quick solution.
I can enter as ON and OFF text just a empty box " ". Then i can keep the font colour but it doesnt display any text.
But now it shows also the on/off images. But like you said it's a bug, as it is working properly in TS.
So now for me there is just the thing with generic inputs and the bottom navigation bar left.
And BTW: For connection SD to the Megasquirt with USB cable, i always need to ground the "ID" port, so that OTG of the tablet gets activated, is this right?
And because i never testet: Which values are included in the DataLog file in SD. Does it record everything like Tunerstudio or just values which are in the dashboard?
Speedy_G
Postby LT401Vette » Wed Apr 27, 2016 11:29 am
Dashboards with Generic input gauges will save with TS 2.6
Not following?
It logs everything TS would plus GPS and Acceleromter data.
Generic Sensors won't log with the name assigned in TS though, they will log as the default names: "Sensor01", etc.
However, if you load an msq saved with TS that will assign the proper names.
LT401Vette
Postby chris_xtreme » Sun Jun 12, 2016 6:15 am
flyguyeddy wrote:Yea the date is good.
Did you work an odometer into the program? Would it be difficult to change the gauges at the user level (say I wanted an oil pressure gauge)
Hi, sorry for waking up a sleeping thread, but did an odometer make it into shadow dash?
many thanks,
chris_xtreme
Postby LT401Vette » Sun Jun 12, 2016 12:37 pm
Actually a new function to support that just went into TunerStudio last week, that will be available in Shadow Dash the next release as well.
LT401Vette
Postby chris_xtreme » Mon Jun 13, 2016 3:07 am
that is great news,
I have picked up via uk ebay a panansonic toughpad tablet for £80 and am planning to make it my dash, the odomoeter was the only thing missing. Only android 4.0.4 but it should do and be good to bolt up behind the dash. (in a kit car, so can make a hole)
(I'm on ms 1 so I know my fuel guage will have to be off screen, but I can cope with that, probably get a led bar one)
cheers
chris_xtreme
Postby mrpham » Thu Nov 17, 2016 8:25 pm
Hey guys.
Been using Shadow Dash for a few weeks now and I've noticed that after connecting or disconnecting shadow dash to the ecu (over bluetooth) causes the engine to stumble. Just like when you burn a tune while engine is running.
Is this to be expected? Or is something else going on here?
Thanks!
mrpham
Postby LT401Vette » Fri Nov 18, 2016 11:14 am
mrpham wrote:Hey guys.
Thanks!
MS2?
For MS3 SD does write data to the controller, but for MS2 or MS1 it should not do any writing.
LT401Vette
Postby mrpham » Thu Dec 08, 2016 7:04 am
Thanks!
MS2?
Hey Phil.
It's a MS2 (DIYPNP), but it doesn't always happen though. Seems random?
mrpham
Previous
