Shadow Dash Ms2 Fw3.3.0
Hello,
yesterday i've updated my MS 2 to the Brand new 3.3.0 Release Fw.
Then i've tried to work with Shadow Dash.
The Connection is okay but it doesn't show any values.
I've looked in Debug.txt for what is wrong and there was a Message that
i should update Shadow Dash to match the Firmware.
But there is no update available or i'm wrong?
Where does Shadow Dash get the correct megasquirt.ini
Best regards
Best regards
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Re: Shadow Dash Ms2 Fw3.3.0
For 3.3 firmware, you really should be using the beta Shadow Dash. I'm now focused on getting the last couple things ironed out to promote it to stable now that the MS2Extra 3.3 has been promoted.
To get the beta:
http://tunerstudio.com/index.php/produc ... ta-testing
To get the beta:
Phil, I followed your instructions for the beta via the play store but don't see an option to join that Google beta group? I did search some other random groups and do see an icon to join but not on yours?
Mike
Mike
On another note, is there a way I can transfer from the Google play license to the manual download version? Seems like a better setup.
Mike
Mike
I have installed the Beta Version now.
Connection works.
But i need the Registration Information. FYI i have already a Shadow Dash Licence payed at Google Play.
What should i do to get the Registration informations?
Best Regards
Connection works.
Best Regards
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
If you purchased it from Google Play, you need to get the beta from Google Play. The downloaded installer only uses registrations from EFI Analytics.
Phil wrote:
Waitin' for the next full release, which I assume will have to come from Google to keep up with the registration.
I got Shadowdash from Google Play also, then the beta from EFI Analytics. Now, I'm with myk777 -- I need the Registration info to get out of "Demo Mode." But I just looked and Google does not have the beta -- their latest is v1.01.If you purchased it from Google Play, you need to get the beta from Google Play.
Brian
MS3-3X v1.3.0; TS Ultra 3.0.28; 911SC 3.0L; 3.2 intake; 2 Spartan O2 sensors; LS-2 coils; 60-2 geartooth and hall; dizzy hall
You can get the beta from Play too, it is just a bit more PITA. So far that is what Google Play has been to me a PITA.
The instructions above tell how:
It is primarily that you have join the google group EFI Analytics Beta Testers, then you can turn on and off whether you want to get the beta versions.
Problem solved, for whatever reason when I tried joining the google group though the laptop it worked, not sure why it wasn't working on the nexus 7, but anyways its working now.....but yeah what a PITA, wishing I wouldn't have purchased though the play store now.myk777 wrote:Phil, I followed your instructions for the beta via the play store but don't see an option to join that Google beta group? I did search some other random groups and do see an icon to join but not on yours?
Mike
Mike
I got so tired of google play I just re-registered on the website and went at it that way. Well worth the second $9.99 in terms of less hassle as far as I am concerned
Support the developers!
Me too. Got v1.0 from Phil and Google updated to v1.01 the next day.I got so tired of google play I just re-registered on the website and went at it that way. Well worth the second $9.99 in terms of less hassle as far as I am concerned
Brian
Now i have received the Beta Shadow Dash.
It works fine with the FW 3.3.0
No problems so far.
No problems so far.
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
